I was just wondering what the max rpm for my 150 hp motor should be at full throttle it will ony reach 4400rpms. It seems to me it should max out at 5500-6000 range if so what could cause the low top end. The motor doesn't miss and runs strong.
1989 Yamaha 150 hp max rpm is only 4400
Originally posted by erock7678 View PostHow do I know what size prop to have on it? My boat is a 21 ft. Proline w.a.
Outboard Performance, Performance Bulletins | Yamaha Outboards
Originally posted by ausnoelm View PostWe need to know if it ever reached max RPM, or you will be chasing your tail.
This is all assuming no engine issues.Last edited by Jason2tpa; 07-02-2016, 06:36 PM.Jason
Also, and I'm repeating what the pros on here told me, if your engine is not reaching spec rpm range at WOT you've got a problem. Once you check your props pitch, if it's on the low end (13-17) then you can rule out the prop. Bc a lower pitch prop produces a higher rpm. Again, assuming all other factors are normal. Good luck and let us know.Jason
Originally posted by rodbolt17 View Postactually??
find a dealership that has test wheel #YB-1626.
install the test wheel and back it down the ramp and see if it will turn it to 4600-4800.
if it will fix your prop/rigging issue.
if it wont fix the motor and retest.Jason
Originally posted by ausnoelm View PostSee where he said "test wheel" , guess what a TEST does?Jason
Originally posted by Jason2tpa View PostI've never used one, though the concept makes sense. However, I'm not familiar with how the test prop accurately determines rpm when no load is applied. If you are please explain.
I gather it puts load on the prop shaft (while still on the trailer, backed up to water) and allows the engine to be in gear at full throttle simulating WOT for testing purposes..(engine is going up in RPM's as if in open water)Scott
ÂÂÂ
