As a lot of you know, I recently did a tear down, cleaning, and reassembly of my motor due to my first overheat problem and finding clogged cooling passages.
It does run great, starts on the dime, accelerates like a shotgun, and never misses a beat. Plugs are burning with a nice chocolate brown porcelain insulator color. Actual WOT rpm is 4,800, within max range of 4,500 to 5,500 (I'd like to reach 5,000 or a bit above). Boat is fully loaded, with a four blade prop (Pitch and diameter, I forget).
I'm now at the stage of fine tuning all the components/systems within the motor. I'm replacing somewhat soft fuel rail hoses that lose black residue If I rub them with my thumb. I'm also adding a fuel management sensor and meter.
When I first got the boat/motor, I did have fuel system issues (Clogged VST filter, bad O2 sensor, misadjusted oil pump link (way too much).
Do you guys think I'm going overboard if I pull, check, clean, and replace if necessary the fuel injectors. In the 15 years this motor has been in service, they have never been pulled (still has factory yellow paint on the fuel rail bolts). I'd like to check fuel economy with my new fuel management system before and after the fuel injector service if I decide to do so. If I don't get the WOT rpm I'd like after this, I may think of reproping.
Townsends, so much for "Kiss", huh. But, I do want to get maximum performance out of her!
Please give me your opinions/advice.
Thanks, Chuck
Thanks, Chuck
