have a 2000 250 hp ox 66.while running engine dies.traced it to high pressure pump.No power to pump.Put power to pump sometimes still hard to start.When cranking almost sounds like no compression cranks fast.Sometimes i spray a little 2+2 in intake and it restarts.Ive replaced the fuel priner ,lo pressure pumps, filters ,plugs,bypassed the fuel tank ,cleaned the vst screen.Dont know wha to do next.Sometimes cuts out at idle as well,but mainly at speed.
2000 250 hp ox 66 high pressure pump looses power
Originally posted by reelfriend View Posthave a 2000 250 hp ox 66.while running engine dies.traced it to high pressure pump.No power to pump.Put power to pump sometimes still hard to start.When cranking almost sounds like no compression cranks fast.Sometimes i spray a little 2+2 in intake and it restarts.Ive replaced the fuel priner ,lo pressure pumps, filters ,plugs,bypassed the fuel tank ,cleaned the vst screen.Dont know wha to do next.Sometimes cuts out at idle as well,but mainly at speed.
Are you saying that when you connect the positive lead of your voltmeter to the terminal at the pump that is connected to the red wire with a yellow tracer, and the negative lead of your voltmeter to the block, that you are not seeing voltage to the pump? With the key on of course.
No voltage to the pump indicates a broken wire, bad connection, defective relay, etc..
The voltage source also applies voltage to the fuel injectors. If you are manually pressurizing the fuel system when the engine is not providing voltage to the pump and injectors, guess what? The motor won't run. Even though there is fuel pressure the injectors won't open to spray the gasoline into the intake system.
The injectors and the fuel pump get their voltage from what is called the main relay. The relay control circuit (opens and closes the relay contacts) gets its voltage from the CDI.
First thing that I would check is to see if the relay is closing when the key is turned to the on position.
If the relay is closing does the relay have voltage to it from the battery?
If the relay is not closing then I would check the wire from the CDI to the relay control circuit.
