Trying to get some clarification based on earlier posts. I located and not currently hooked up on my 2004 F150 TXRD. Based on my understanding or lack of, the single function of this pigtail is to charge the house battery (#2) when battery switch is set to #1. If #1 is then drained during use, #2 can used as it will or should be fully charged.
Having said all that, Rodbolt suggested using a heat shrink connector to connect the pigtail to a 10 ga. fused wire. (removing Yamaha installed connector) Does it connect directly to positive terminal on #2 house battery?
