I have a few questions.
I recently rewired my boat as some already know, and while out today we did a run out to our local sandbar. This is wot for about 10 minutes minus bringing the throttle back for some big waves, and everything was fine. We sat for a couple hours, and on the way home about 5 minutes into the trip at WOT i suddenly dropped from 5200 rpm to 4800 and eventually 4600 and it wouldn't go over it. I stopped, revv'ed the engine in neutral and was able to hit 5200 easily. I didn't sit at 5200 in neutral for more than a couple seconds, but when i went to take off again it was struggling to get past 3800 RPM and then it was surging to get back to 4800. I brought it back down to 1800 RPM and made it back to the dock. It idles fine, and it starts fine. I was thinking either or both fuel issues and spark plugs. I have only had the boat a couple weeks, so I figured changing the plugs and the fuel/water separator filter would be a good place to start. I wasn't sure if I didn't hook something back up electrically or if that mattered for this engine since its a carb. and not EFI.
I did recently change the fuel tank vent as the previous one was sheered off. I filled up and could see the fumes coming out so i'm assuming that it was working correctly (its a p style so water can't go back inside the tank) so i'm hoping its not a fuel tank supply issue.
second question, my trim and tilt yamaha gauge doesn't work. It hasn't since i've had the boat and didn't work before the rewire. It shows the engine always in the same place, on the last bar i think its #1. Its a Yamaha trim system so where should i start to trouble shoot that?
I think thats all I can think of
