I have a 2014 200 HP Yamaha in line four and while traveling at 15 MPH I ran the prop into a shallow muddy shoal. The prop does not appear damaged howeve at low speeds the boat feels like it is dropping in and out of gear. The feel is random and inconstant. At higher speeds it feels ok. I removed the prop and the plastic shear inset looks good, the splines are fine and the runout on the shaft is perfect. Does anyone have any idea as too what could be causing this.
Fishing Fool
Part #21 :
2006 and Later F200LB Yamaha Outboard LOWER CASING DRIVE 2 Diagram and Parts
is that what you checked?Scott
Â
