I'm running a 13" prop on my 2010 t60 which is mounted on a 17' Alii Kai. Loaded for a typical day of *****ing, at wot, I'm reading 57-5800rpm@26 mph(gps). Am I close enough to specs or should I consider re-propping......you know I'd like to go faster,right! Thanks in advance for all of the expert advice .
Propper prop?
do a search on the Yamaha Performance Bulletins for a rig like yours to see what motor and prop they used and what performance they got.
diameter and pitch along with material it is made of along with the shape and # of blades make a difference. not just a 13"prop .
depending on how you load it you may have to try several to find the right one
