I can't seem to get my Multifunction Tach to respond to the trim sender.
This is a new install and the tach works fine.
It shows full bars with the top bar flashing
I have verified the signal to the gauge and set the dip switch for 2 wire sender.
At the motor end (New 50HP 4 Stroke High Thrust) the signal goes from a black and white wire on the sending unit to a black and a pink wire on the connector for the harness. The pink wire then goes to a white/red ?? (I'm color-blind) in the harness to the same wire color on the gauge.
The Resistance reading on the black to red/wht goes from 0 ohms to 360 when actuating the sending unit.
Please help.
Also a wiring diagram would be very helpful if any one has one.
Please help.
