Hey boys. I've previously posted about my malfunctioning tach gauge. Made the suggested checks. Got it functioning, then it would crap out again. The short and sweet of what i'm seeing now is nothing. When I start engine I can barely see numbers. After a few minutes of running engine the screen is blank, yet the back light does work. Of course I'd rather replace wiring versus buying a new tach, but I've hit a wall finding a short, if there is one. It's the older version tach and I bought the boat used, so for all I know the tach could be as old as the engine ('98). So maybe it's just time to replace. Your thoughts.
And another issue I'll include because it's probably related to above is the alarm. When starting the engine for the 1st time of the day, and ONLY on the 1st crank of the day, about 75% of the time the alarm will sound. The alarm will actually sound when turning the key to the "ON" position, before turning engine over. I'll start engine and the alarm will continue for 10-15 seconds then stop. During this time the engine continues to run. I can't tell you what the tach screen is indicating (see above) as to why it's alarming.
So, I assume the above 2 issues are related, though not certain. I'm lost as to why the alarm will sound when the key is in the "ON" position, before the engine is even turned over. Though if the issue is with the tach being fouled, maybe that's why. Let's hear it guys. Thanks.
