200 hpdi rough
  • 200 hpdi rough
    on a 2003 200 hpdi idles ok about 1400 1700 rpm runs rough all filters changes
    what should i check,no codes
    Check to see if plugs are fouled, or make shore you have spark,
    Water in fuel is a good start
      Drain the VST also and catch what comes out with a clean container.
      A couple of pumps of the primer would help flush the system up to that point...
