Cables
  • Cables
    Hi
    I need to replace my control cables the yamaha part number is ABA-CABLE-10-GY can some tell me if teleflex has a cable i can use in place of this one and the part number it is a 10ft cable and need both of them
    Yamaha cables are made by Teleflex. Branded as Yamaha for Yamaha.
    Of course Teleflex makes a cable that you can use in place of the Yamaha branded cable.
    SeaStar Solutions
    The 10 denotes a 10 foot cable. Just buy a Teleflex branded cable for a Yamaha that is 10 feet long.
    Yamaha Outboard Control Cables | eBay
      So the teleflex 3300 is the same as ABA-CABLE-10-GY
        Can any confirm this for me that ADA10GY is the same as TELEFLEX 3300
          More than likely only Teleflex will be able to confirm that the Yamaha branded ABA-CABLE-XX-GY type cable made by Teleflex is the same as a Teleflex 3300 cable.
          I would suspect that the Yamaha cable offered today (Premier II MAR-CABLE-XX-SC) is more or less the equivalent of the Teleflex Xtreme cable.
          Same may be true of the lower quality Yamaha/Teleflex 3300 cables.
          But you need to hear this from Teleflex. If they are talking.
          SeaStar Solutions
            Thanks for that in for look like CCX633 is going to work
              One more question is the Throttle and Shift Cable the same cable i was looking at the ones on the boat and one is a little bigger around than the other one
