25 hp Merc wont run w/o with cover on
  • 25 hp Merc wont run w/o with cover on
    With the cover on, My motor will start great and putt along at low speed fine, but when I crank it open it, it tries to get up to speed but then dies.
    With the cover off, it starts and runs great and runs like a top at w/o throttle.
    I thought it was sucking exhaust in so I replaced the exh. manifold gasket. I also made sure the wires from the coil to the spark plug were not getting bent down causing a bad connection.
    But I still have the same problem????
    Seems like it's having trouble breathing with the cover on, but there's nothing obstructing the air intake on the carb. I'm baffled???
    Possible carb problem, check air passages in carb and clean carb.
