I just purchased a 2005 F150 with 132 hours, it looks like the guy never rinsed the motor. Motor was not shooting out water from the side hose when I tested the motor in the water before purchasing it. The boat/motor did make it to full RPM and ran well, no alarms went off. I changed all the fluids, spark plugs, fuel filter, water separator, thermostat, water pump and impeller. When I removed the poppet valve and thermostat I found lots of salt and black plastic looking debris. I tried blowing through the side hose with my mouth and could not, so I used a compressor and it unclogged it some. The motor shoots water out now the side hose when I run it on the muffs but I don't think the stream is strong enough. What should be my next step?
Thank you,
Jose Sirven
Thank you,
Jose Sirven
