YDS Error"engine not in nuetral or in gear" for static YDS teat
  • YDS Error"engine not in nuetral or in gear" for static YDS teat
    I am trying to run a stationary test on my 2007 Yamaha F115. Everything is reading but when trying to start the test there is an error saying "engine running or not in neutral". It won't let me do the test. Trust me when I say the engine is NOT running and throttle on handle is in neutral. Please help, I have been trying to figure out a couple issues with rough idle and some stalling. I can run the test if I pull the wiring harness off of the throttle position sensor. I have static YDS if wanted.
    typically it is due to an incorrect TPS setting.
