OK so here's my latest zaniness
recap: my F225TXRD mfd 11/04 was built with the engine harness design for Command Link;
although the -30 ECU wasn't fully capable, I've replaced that with a -31 and enjoy the N2K output.
Unrelated, last fall, you identified one of the unused connectors on my engine harness as intended for the fuel-filter-bowl -water detector.
I'm thinking if it is for fuel-filter-water,
that on this engine, it is intended as a "Command Link" functionality;
so I'm wondering - what "signal" would the ECU receive
what is the exact nature of the fuel bowl sensor ?
Does it consist simply of two bare conductive terminals?
An obvious "exploratory technique" would be to simply drop that blue connector into a cup of water and see if the ECU transmits a "water in fuel" alarm!
but I'm hesitant to do that without a little better understanding of what I might be dealing with.
Any insights to share?
btw - here'a a summary of the parts listing for the F225 :
seems water detection wasn't added until April 2006, and there was a subsequent change, as well
