What Spark Plugs????
  • What Spark Plugs????
    2000-2001 Yamaha 150 HPDI left hand
    Not sure of the year at this point! I think someone pressure washed the corner of the id tag.....
    What I can read is: Mod LZ150****** 800642(I think it's a 2)
    Coils have grey plug and black coming from the ECU
    The plugs that are in it I believe are BKR6ES and an old set of bkr6eku in the console....
    What does this thing take????
    Thanks..
    Looks like a 2001:
    2001 LZ150TXRZ Yamaha Outboard CYLINDER CRANKCASE 2 Diagram and Parts
    Part #41 which it doesn't specify.
    Boscoe should have the #
      there is a tech bulliten on identifying which plug to use based on coil primary connector color. do not go by anything else.
        What damage would it do if the wrong one was used? Seeing I have both linked to being used do I have to worry?
          back in about 02 or 03 there were some case by case ECU changes, the 05 marine tech guide has the color code for the primary coil connection color.
          the kit consisted of a new ECU,6 coils and 6 plugs.
            I believe he is asking about why these changes were made, and what did they fix.
            Along with what happens if the wrong ones are used.
            was it feed back into the ECU causing it to misbehave maybe?
