Hello everyone
I’ve got one small issue with my engine 2015 300hp with about 30 hours on it. This weekend I was using the boat and all the sudden the engine stopped, as if i had turned the ignition with off, this happen about 4 times during the whole day, no alarms went off, all gages were ok. this happen at different speeds not on idle. On all 4 occasions, to turn the engine back on i just turned the switch off and turned it back on and the engine started with no problem and worked perfectly.
Has anyone had similar issue? what should i check for?
Best regards
Best regards
