Hello,
I am having a intermittent problem that I hoped someone may be able to help me with. I keep getting an overtemp alarm when the motor is not at higher RPMs. I have replaced the Impeller, housing and associated parts. I replaced the thermostat thinking that it might be sticking. I have flushed the cooling system with vinegar, also with simple green to make sure the system had no obstructions. None of the things listed above helped. When the motor is at Higher RPMs, I have no issues, but when running at low speed, the alarm sounds. Any ideas out there?
Thanks in advance,
John
Thanks in advance,
John
