yamaha VZ225 Swivel Bracket
  • yamaha VZ225 Swivel Bracket
    Need to replace bracket
    Is the job hard to do and does the power head have to come off?
    I am a mechanic but never done outboards
    If you are talking about the one I am thinking of the power head, lower unit and everything else will need to come apart.
    Might wait for a reply from someone with better knowledge on this though
      A photo of damaged area would be helpful....
        here you go
          Hope you can see this picture
            Top of steering shaft is down on swivel bracket
            bottom is dropped about a 1/2 in
              myself
              I would check with OBR or another outboard used resale shop and try to buy an assembled good used bracket assy.
              way faster and most likely cheaper.
                I can get the complete bracket. How much work is it to insatll? Can it be done from the bottom up or does the powerhead have to come off?
                  I imagine it would require a very special wrench
                  to get at the heads of those upper mount bolts with the powerhead still in place
