that is a very good question,I do not know myself and I would like to know this also.
seems strange that if the secondary was open it would have been the same as you pulling the plug wire off.
or when you said no reading did that mean 000.0 ohms
looks like that c40 has 3 pulser coils one for each cylinder to tell when to send spark.
I wonder if the voltage from bad coil could cause voltage/current to run through grounds on other coils, or it just caused the timing light to get false reading.
let me know if you find an answer as I have a motor close to what you have
