What is the best method for keeping fuel injectors working optimally?
Fuel Injector Maintenance
Use clean fresh fuel and use the motor often. All of my cars and trucks go hundreds of thousands of miles with no servicing required.
Some will use a gasoline additive to help keep the injectors cleaned.
Some folks will pull the injectors and send them off for a cleaning and then flow test.
Originally posted by boscoe99 View PostUse clean fresh fuel and use the motor often. All of my cars and trucks go hundreds of thousands of miles with no servicing required.
Clean fuel and use it regularly (which should be GOOD thing!) is #1. I also use Startron and Yamaha's Ring Free. It might be a bit overkill, but it's pennies a gallon and anytime I've checked my fuel quality (by draining the hi-pressure pump's tank) it's been super clean. When I clean out that tank, it's also extremely clean.
Check and/or change your filters regularly. I'm adding a vacuum gauge to my main (boat mounted) filter this year. Not that I care about spending the $10 per year on a new filter (although, why change it if I don't have to?), but more of a diagnostic tool.
I did get my injectors cleaned, but I did that when I first got the engine. Everything was running fine, but I wanted to start with a "clean bill of health", so to say. For $120, it was well worth the peace of mind to me.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
ÂÂÂ
