I'm asking this question since I have Yamaha's, but not Yamaha related. I have to replace the scoop pick-ups that provide water to wash down and bait tanks on my boat. The scoop is a Perko with slots for water and a closed round end on the other. I believe it is a model 66-2. Perko says mount with slots forward. This was a factory setup from Boston Whaler but the slots are facing the rear. I am getting reasons for both set-ups. Any thoughts?
Not Yamaha related
With the scoops forward, it'll definitely be picking up and circulating water while under way. It'll still allow a water pump to work while stopped too..
IMO, I'd install them in as directed by Perko.
You can always pull them and rotate if need be.
I'd get a hold of Boston Whaler and ask them just for S&G's. Possibly it was assembled on a late Friday
If it looks like these, I'd be putting them in as directed(couldn't find that exact model):
http://www.boatpartsaccessorieselect...-strainer.htmlLast edited by TownsendsFJR1300; 04-07-2016, 07:46 AM.Scott
I have one of that style, feeding both livewell and washdown, and it faces forward.
The livewell pump is a centrifugal type, so at cruise there is a considerable flow right through it via "ram effect" on the scoop.
Its enough flow to "beat up" the baitfish - I have to remember to close the valve inside the livewell while moving fast.
So, I can imagine mounting the scoop backwards might be desirable.
Now of course, if I was using a pickup like that for inboard engine cooling, I would definitely want it facing forward....
ÂÂÂÂ
