On motors that use the trim sender to inhibit the automatic transfer of oil, if the sender has crapped out/not getting its voltage/been removed from the system/etc. will the oil transfer system work normally when the motor is being operated? If so, is the motor now at risk of the oil pump coming on if and when the motor is tilted up?
Some Yam senders get their five volt reference from the tachometer or trim gauge. Do they all do this or do some get their five volts from a CDI or other source?
