What is the purpose of having twin motors but the kill switch will only shut one down?
Kill switch
It appears that you are talking about a twin switch panel with just one kill switch. The wiring is such that if and when the kill switch is activated both motors will be killed.
If the switch is only killing one of two motors then something is wrong with the switch panel.
Go behind the panel to the back of the kill switch. Should be two white wires and two black wires. Make sure all of the connections are in place and clean and tight.
Check for continuity from each black wire to each white wire when the kill switch lanyard is pulled.
Check for the presence of a ground on the black wires.
2006 and Later Rigging Yamaha Outboard ELECTRICAL SWITCH PANEL TWIN Diagram and Parts
Yes, both assemblies have 4 wire kill switch. One alarms when the starboard motor is cranking over, the other does not. The one that alarms on cranking
does not give the beeping when the key is turned on. The other one does but no alarm on cranking. I am still going through the ground wires.
After some testing I think I found a common link with two different dual key assemblies. Port motor cranks and runs, starboard motor cranks but does not run with disconnect engaged. A couple of years ago I asked why my port motor continues to run for a few seconds after the key is turned off. Same motor that will crank and run with kill switch engaged. Rodbolt told me that it is the white wire on the motor that shuts the motor down when key is turned off. Same wire that shuts the motor down when emergency kill switch is engaged. Conclusion is a bad connection somewhere in the white wire in the wiring harness or where it grounds.
Originally posted by oldcobia View PostAfter some testing I think I found a common link with two different dual key assemblies. Port motor cranks and runs, starboard motor cranks but does not run with disconnect engaged. A couple of years ago I asked why my port motor continues to run for a few seconds after the key is turned off. Same motor that will crank and run with kill switch engaged. Rodbolt told me that it is the white wire on the motor that shuts the motor down when key is turned off. Same wire that shuts the motor down when emergency kill switch is engaged. Conclusion is a bad connection somewhere in the white wire in the wiring harness or where it grounds.
Where does the white wire get grounded too? Is the ground after the switch on the engine block? I tried another harness from the key switch to the motor and still have the same issues. Motor runs for a few seconds after turning key off and kill switch does not stop port motor. I can't help but to think they are connected in some way. Key switch tested and white wire grounds when key switch is off or kill switch activated.
Â
