I recently installed a new tach/speedo for my 2000 150Vmax. When I run it now, the idle rpm seems correct. However when under way, its readings go all the way up to 10,000rpm when at WOT. Don't think its accurate or supposed to be reading this. What would cause this? The speedo seems to be working fine.
150 VMAX Tachometer readings???
3 switchs, that would dipically be the 6y5 Yamaha digital.
out of the box the switchs are set for 4 stroke,2 wire trim and 12 pole alt.
yours needs to be set for 2 stroke, without a year I cant tell you about the trim, and 12 pole alt.
do a forum search or wait for boscoe.
I don't have the information on the switchs here at the house.
reset your switchs, out of the box its set for 4 stroke .
on your trim switch setting.
simply follow the trim sender wire to the connector.
its either going to be a pink and black two wire connector OR a pink,black and orange three wire connector.
