Small amount of oil leaking from the side of lower unit.I have my water pump kit and lower unit oil ready to install, i will do a pressure test at that time. How much pressure should i use? I will be following instructions from a SELOC manual also any comments on using a SELOC manual?
f115 leaks oil from side of lower unit
If the TOP vent plug is NOT tightened to full torque, it will seep.
Just replaced mine as it was starting to seep. The 6' lbs was quite a bit more torque (with a torque wrench) than I was doing with a screw driver alone...Nice and dry now with new gaskets.
Obviously, make sure you have the OEM gaskets installed...Last edited by TownsendsFJR1300; 02-01-2016, 09:27 AM.Scott
115 leaking oil at air vent
The leak comes from the single side hole beside the water intake,some refer to this as an air vent but I am not sure what it's called.looking at the scematic it looks like it might have some function with the shift cam housed inside the lower unit.Going out today changing and checking crank case oil. Starting her up, then draining lower unit oil checking that.
Originally posted by 99yam40 View PostIt might overheat without water to the block and head though
Guess I pi$$ed off 1styamaha, a PM from him;
"go iron your pants .car dealers suck,boat dealers are like yourself unexscusable."
No joking around guys, this is serious!!!!!
.Last edited by TownsendsFJR1300; 02-01-2016, 08:30 AM.Scott
ÂÂÂÂ
