I am trying to determine the bracket and sending unit switch for the trim and tilt mounted on the main frame which is bolted to the transom. L225 txrv, 1997
97 Yamaha trim bracket and switch
Or 5, 6, 7 & 8 in the illustration at this link.
1997 L225TXRV Yamaha Outboard ELECTRICAL 2 Diagram and Parts
You are correct, it can be.
First time I saw an engineering drawing of a complicated detail part I did not have a hot clue what I was even looking at. All I saw was a piece of paper with some lines and words on it. The engineer I was with thought it was all self explanatory.
Originally posted by cliff mock View PostThanks, sometime it is difficult with parts dia. unless you do it all the time.
BTW, what specific part was it you needed?Scott
Â
