Hi, I have a 2001 Yamaha 40hp 2 stroke that will not idle. The motor starts and idle very rough and then dies. The issues appears to be with the number one cylinder. If I disconnect the number one spark plug wire, the engine will stabilize and idle on two cylinders. If I reattach the number one plug wire the engine will sputter and die.
Also, a spark is visible between the number one coil and the engine, where the coil is attached. The plug wire seems charged along the length of the plug wire, as a slight sparking is present when the wire is touched.
I swapped out the coil, but the same issues as stated above remains, including the coil to engine block sparking.
Compression is good on all three cylinders.
Spark check good on all coils.
Swapped around spark plugs from cylinder 3 to 1, but no difference, same symptoms as above.
Any advice on what is causing this issue would be greatly appreciated.
