Drive shaft bearings. How are they supposed to work?
When I took my LU down I noticed I could wobble the lower part of shaft around a lot and I thought I understood why the two sealing was leaking water into gear housing. To me bearing arrangement is a mystery.
Close to pinion there is a needle bearing taking radial load and no axial load. So far okay. Next bearing, in top of LU, a conical roller bearing turned so it takes axial load pointing downwards but load from pinion gear is pointing upwards. If there is no axial load on this bearing it is not stabile radial and shaft is wobbling around and seals are leaking.
Only way it has worked as I understands, is if there a axial load on the upper shaft end keeping the conical bearing under axial load in all situations.
