I would think the 4.9 volts, key on, engine off is the 5 volt reference supplied to the sensor. Once engine starts then voltage on return wire to ECU should drop to corresponding pressure the sensor is seeing.
If you see no change in voltage after starting then that points to bad sensor. BUT you swapped sensor for a known good one with same results. So that would point to a wiring/plug problem from ECU to sensor?
Was continuity checked on the wires between sensor plug and ECU plug??
