The solenoid tested ok, so I put it back in checked all the connections and found that the inline fuse all though not showing blown was faulty I put in a new fuse and the engine cranked without the key just by making the connection at the fuse. I then thought the ignition might be the problem so I have the whole ignition and kill switch disconnected and the engine still cranks when I make the connection at the inline fuse.
What can be going on ???
Thanks Jimmy
Thanks Jimmy
