Hi Everyone,
2000 Yahama SX 250hp OX66, 3 blade prop 15-1/4"X15"-M.
Boat: 1989 Mako 231 with A&J full flotation bracket.
Motor runs fine for a while (15-25mins) at all speeds and RPMs (wot @ 5500-5700), soon as it gets warmer and it hits 4000rpm or over, shuts down, like if I turn the key off!!
After the shut down, motor starts right away, when cycle the key off-on !
This is what I checked and replaced so far:
O2 sensor brand new and clean.
VST filter clean, preasure regulator screen clean.
New VST gasket.
Inline fuel check valve gutted (I was good, but removed just in case).
Injectors clean (fuel injector man).
Fuel preasure on rail @ 40psi at idle.
3 new low preasure pumps and gaskets.
TPS voltage check, 0.50v fully closed
Compression 110 all 6.
High-Pressure Fuel Pump Resistor: 0.70 ohms.
New spark plugs.
Spark gap good.
Gas and tank are brand new, all filters are new, and new yamaha primer bulb as well.
Motors idles fine, minimun smoke.
Still need to check pressure on rail soon after shut down and HP pump amp draw.
Just order a winky blinky harness from SIM to check on the other sensors, should be in by the end of the week (12/24/2015)...
Any other suggestions??
Thanks,
Eladio
New VST gasket.
New spark plugs.
Spark gap good.
Thanks,
Eladio
