1998 2 stroke 115hp. Hey guys what's your take on fresh water flushing with ear muffs versus using the hose attachment installed in bottom cowling? The only difference I could come up is the muffs flush out the water pump housing. Your thoughts? Thanks.
Muff flush vs. Hose flush
Maybe a year or so ago we had a similar thread. Good info and changed my mind, but not my habits.
The one I liked was the rig with both muffs and hose connection.
Either is likely fine, but I suspect rodbolt's heard diligent attention from owners and neglect from their outboards.
Running on the MUFFS and getting to temp, allows water thru the thermostat where the other does NOT (plus the water pump).
Once I get in, I'll use the power head hose flush for maybe 10 minutes. Once on the lift (and out of the water), the muffs and run it another 10 minutes or so.
I have plenty of water pressure (no overheat alarms on the muffs), but should you get an alarm stop.
What some use is a combo "Y" hose set up. One hose runs to the muffs, the other to the power head flush hose. The "Y" adapter (common garden hose Y available at Lowes, Home Depo, etc) comes with a small lever to adjust water flow more or less to each one..
Somewhat related, if using the Yamaha Water pressure LU hole for the speedometer, I also flush that as well (especially with salt water use).
http://www.yamahaoutboardparts.com/f...g-th23159.html
.Scott
Good stuff townsend as usual. Video was good too thanks for the link.
Originally posted by TownsendsFJR1300 View PostRunning on the MUFFS and getting to temp, allows water thru the thermostat where the other does NOT (plus the water pump).
.Jason
Not mentioned anywhere I have found with two stroke V4 and V6 there is a bolt at the top of each head water jacket that leads behind the thermostat water passage. Fitting a water hose to here allows flushing as if the thermostats are open (as if engine warmed); this combined with the provided flushing point eliminates the need to run the engine!
Your welcome for the link, etc.
Just a side note from my previous Evinrude V6 150 before I re-powered to the Yamaha.
Back in 1997, the engine did not have a "flushing hose" built in, thus, you HAD to use muffs. I had the original thermostat installed for the entire time. And of course the 2 stroke is MUCH noisier flushing/running.
Evinrude came out with an adapter to the power-head (rear of the engine) that allowed flushing W/O running the engine.
After installing that and using it, (NO MUFFS) within TWO YEARS, my thermostat clogged up with salt big time...(I have to assume salt built up elsewhere as well). Coincidence? No way.....
I'm still on my original thermostat on my 06 F150 BTW (low hours too)Scott
Originally posted by rodbolt17 View PostI run them everyday on the factory flusher.
never melted a pump never had an overheat.
Thursday I had to run an SX250 that I had just replaced the powerhead for about 15 min.
for that I used BOTH a muff and the factory flusher.
I have run many a Yam using just the garden hose flush fitting to supply water to the motor. Nary a problem.
Water goes into the block, fills the block and then runs down the water pump tube where it flows into the water pump and lubricates the vanes of the impeller.
This continues to be a widely debated topic. Mostly because Yamaha expressly states in the owner's manual to not do it.
Here is a photo of water being supplied to an F150 via the garden hose fitting. Water is now flowing out of the block, through the exhaust system and also to the water pump. Motor is not running at this time.
ÂÂ
