I have a 50hp-89. Water in oil coming through water pump seals. I want to disassemble the LU to check bearings etc. I had to drill and split the cover nut, but now I cannot get the bearing hsg out. I made two "puller hooks" from 10 mm bolts (as shown in many Youtube wideos) and have them pulling from prop shaft end. It is not moving at all.
Next is heat and hammer. Here I need help. Where to heat and how much? Is it most likely to be stuck in the front part of the bearing hsg and in that case how far from rear end of LU housing is this? Any way to check I am not overheating the LU housing. What kind of grease/anti-corrosion paste shall I use during assembly to avoid/delay freezing?
