1999 yamaha ox66-225 outboard
  • 1999 yamaha ox66-225 outboard
    Recently had problems starting my engines. At first thought I had water in fuel lines. It turns out that the dual main swich is defictive. In order to start any engine, one has to make sure that both keys are in the on position. If you cut off one engine that other engine will die. Thought this might be interesing info. to someone who encouters the same problem. [img]smile.gif[/img] wvashaw@vashaw.com
    The dual Key Switch has a Module that can cause the that kind of problem. The part number is 61B-82570-02-00.
