I replaced on of my F50's this year, the engine is near new and has done about 300-400 hours so far. It is on a commercial fishing catamaran. The last couple of weeks I have been getting a low oil pressure alarm. It has done the same sequence each time:
Engine will start normally without incident at the start of the day.
I leave them to warm up at idle
As soon as I go into gear for first time the alarm sounds (or if I increase revs in neutral by depressing button)
I turn engine off, reset gauge (I have digital gauges), and restart engine.
The alarm will sound for a second time but not untll engine reaches 1200-1500rpm this time
I turn engine off, rest gauges and restart
Engine will then work normally for the rest of the day with no further alarms
Oil level is OK
I'll admit I've not done much more investigation, but just thought I'd post on here in case there is something obvious I am missing. Can get more info if required. I don't have pressure gauges, and the digital gauge isn't hooked up to display oil level, i just use dipstick. The weather has turned colder recently, not sure if this would have any impact. On the mornings the alarm has sounded it has been 0-5 centigrade (32-41F)
TIA
Oil level is OK
TIA
