I have a 1992 40MJHQ 3cylinder 2 stroke I'm trying to replace the head gasket and head cover gasket. I got all the bolts loose but cant get the head to break loose. I tried a few good blows with a dead blow hammer but it seems to be realy stuck. There is no good area to pry on it like some areas have. Any ideas? thanks.
stuck cylinder head
Originally posted by evinrude25 View PostI have a 1992 40MJHQ 3cylinder 2 stroke I'm trying to replace the head gasket and head cover gasket. I got all the bolts loose but cant get the head to break loose. I tried a few good blows with a dead blow hammer but it seems to be realy stuck. There is no good area to pry on it like some areas have. Any ideas? thanks.
I would triple check that you did get all the bolts out. It shouldn't be that difficult. ..
Here's the parts fisch to compare to;
1992 40MJHQ Yamaha Outboard CRANKCASE CYLINDER Diagram and PartsLast edited by TownsendsFJR1300; 11-18-2015, 05:34 PM.Scott
Thanks for you response. Yes I'm certain I got all the bolts 1-14 it's great Yamaha numbers them. I could try cranking it over with the plugs in, then try the wood shims. Will try this weekend, Thanks again. This Yamaha forum is great-very helpful!
The last 200, 2 stroke I worked on where we pulled the heads, as I re-call, there was some small tabs on the head .
If not, perhaps pull the thermostat, and use that opening with a piece of wood to break it loose with a BFH.. Gently first...Scott
ÂÂÂÂÂ
