My 2004 yamaha 90tlrc won't engage reverse but it will engage forward, so I disconnect the shift cable from the engine and I can shift the remote control into the forward and reverse mode no problem.
Originally posted by fastback4 View PostMy 2004 yamaha 90tlrc won't engage reverse but it will engage forward, so I disconnect the shift cable from the engine and I can shift the remote control into the forward and reverse mode no problem.
did you remove and replace the LU just before you noticed this problem?
oh wait I know,,,lower unit? no but the dealer I bought this from says they installed a new impellar
by the way, the below post from me also happened the same day
http://www.yamahaoutboardparts.com/f...r-th26116.htmlLast edited by fastback4; 11-18-2015, 01:42 PM.
here is the follow-up with my 2004 yamaha 90tlrc won't engage reverse. The dealer mechanic and myself looked at it and the metal clip that holds the neutral safety start switch in place came off, the clip fell under the shift lever that goes to the gear case making it not shift into reverse and the neutral safety start switch was not accuated completely because the clip fell out so it would not start with the key.(another post I made)
ALL FIXED!! See original post;
And for the op, if you can keep it all on one thread is MUCH EASIER.
Making your own thread (and you did) is better too than adding to anothers engines issues.. Tks!Scott
ÂÂÂÂ
