NO volts in PRO V
  • NO volts in PRO V
    Had the boat out the weekend and the engine was running fine. pulled into the beach turned the engine off had lunch went to go back out and nothing!!!!! No power on the dash, no power on the handle control for trim and tilt, no digital gauges. tested the isolation switch and its working perfectly. Is there some fuses that I should be looking for under the engine cowl???
    Engine is p200TLRP Pro V 200 Carb 1991. any help is appreciated. Cheers Jay
    Check your battery, battery terminals and cables.
    See if you have 12/13 volts at the battery and work from there towards your switch, etc..
