I have a 1996 S250TRXU that I've owned for about a year. The prop shaft housing has a grease fitting at the 3:00 position as you look at the prop shaft. I can't get any grease into it, even after replacing the zerk fitting. My guess is that this has not been greased in a long time and it is probably plugged up.
What's the best way to clean this out - remove the grease fitting and shoot it with solvent? Maybe penetrating oil? My worry is that I could possibly destroy the shaft seal (which looks great for now). Thoughts?
