Command Link Plus Gateway Question
  • Command Link Plus Gateway Question
    Does anyone have the installation instructions for the Yamaha CLP gateway part #6Y9-8A2D0-20? I am trying to get the information for the status of the led lights (mine has two) and what they indicate. I now have solid green and blinking yellow with main switch on. My color display gauge works fine.
    I have completed the gateway install but I do not see any engine info on the Garmin (4212) chartplotter and I am sure I have missed a step.
    I think I reset the CLP display to initialize the connected CLP gateway,but I'm not sure how you know.
    Perhaps something needs to be turned on in chartplotter?
    The N2K network is working and I see items in the list BUT I do not see my two Yamaha F300 4.2L engines.
    Here is Yamaha's installation instructions,6Y9-8A2D0-20-00.pdf
      Thank you very much. This is what I needed.
      Chuck
        To close this out: the steady green LED and steady flashing yellow LED for the CLP gateway meant all was well with Yamaha buss and N2K network. The problem was my configuring of the Garmin chartplotter, which ,once corrected, everything is working as expected.
        Thanks again
