2008 Yamaha 60 hp 4 stroke outboard engine. Recently changed the oil. Replaced drain plug with new washer. Tightened to torque specs 13 ft. lbs. Plug has slow leak.
I drained new oil and installed another, new washer, refilled engine oil, and replaced plug, to spec. torque pounds. The plug still leaks.. The plug is not stripped.
I have been very careful not to over tighten the plug.
Any advise would be appreciated. Is there a better "sealer" washer available then the OEM factory ones?
Thank You for any ideas,
