I recently bought a 18' Boston Whaler with a Yamaha 150 HP 2 stroke 6 Cyl motor (carbs). I was fixing some cables at the battery and by mistake shorted the + and - cables. Now it wont start (no spark at any of the cylinders). I disconnected the main plug from the engine to the rest of the boat and tried to jump start it directly from the starter solenoid to isolate the problem and still no spark, so I suspect the prob could be the CDI, Stator or Trigger. How can I test the CDI and other components? Also, the serial number plate for the motor is missing so how can I know the year, model etc of this motor to be able to order parts?
CDI is a kokusandenki CU2684, voltage reg is 6G5-A0. Its a 2 stroke with no VRO, 6 Cylinder with carbs.
Will appreciate any help
