Prov 200 burned no1 piston
  • Prov 200 burned no1 piston
    Was running at 5000rpm when I lost power .
    I shut down.
    When i came home I pulled the head to find a melted no 1 piston.
    Everything looks good no water in oil. carbs look good.
    I did find my oil pump linkage (the plastic part) cracked. So the pump lever was not in the correct full throttle position maybe 3/16 inch.
    Only No 1 shows any damage.
    Scott Lewis,Gary Yamamoto Custom baits, StayNCharge systems, Bassmedics, Savephace
    Scott,
    Sorry about your misfortune.
    I wonder why only one piston burned, since all six were gettting the same ratio of oil/gas from the carbs ?
    Maybe the carb that feeds #1 piston is running too lean?
    Let us know what you find out,
    Ken K [img]smile.gif[/img]
