Anyone know what the Yamaha part no. is for a 2023 Yamaha F60LB engine and what the prop nut torque is? The owners manual says 25 ft. pounds but when I took off the aluminum prop that had been put on at the dealership to replace it with a stainless steel one it seemed looser than that. Just wondering.
Yamaha F60LB prop nut kit & torque specs
I don't know, but is it a nyloc nut or a castel nut?
Either way, unless it's damaged, there is no reason to replace it. Especially since it's brand new - I wouldn't even replace it (blindly) at 5 years old (or, really, not even at an older age, still).
It may not have been put on to the right torque spec to start with. Or, it just needed the typical "check up" after some use.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by dredgerat View PostAnyone know what the Yamaha part no. is for a 2023 Yamaha F60LB engine and what the prop nut torque is? The owners manual says 25 ft. pounds but when I took off the aluminum prop that had been put on at the dealership to replace it with a stainless steel one it seemed looser than that. Just wondering.
After decades, Yamaha finally got it right. You might want to consider doing that also.
Maybe panasonic will ring in. Let's see what he has to say.Last edited by boscoe99; 06-18-2023, 10:27 AM.
Originally posted by DennisG01 View PostI don't know, but is it a nyloc nut or a castel nut?
The reason I was wanting to know was to order a spare kit in case I ever had to replace the original, it is a bronze castle nut.
All that said, I don't doubt some people do torque them - and that is TOTALLY fine - I'm not knocking ANYONE for doing that in any way, shape or form. "For me"... I've put on a couple hundred props and I have never torqued them - although I think most will agree that you start to get a "feel" for things over time... so maybe that IS sort of like torquing?2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Yes I noticed that it didn't seem to be up to 25# at the time I switched props but the only reason I mentioned the 25# part was I had read it in the owners manual otherwise whenever I changed a prop on the old motor I just tightened it up snug where I could lock the nut and leave it at that. Thanks to all who responded with help and comments.
Are you sure? Stop and think about what you wrote. You are making a mistake that millions make. Those who either don't know, don't care to know, or are just sloppy.
I did notice when working with the Brits ,when we had BAE 146 jets, that they mostly said pound feet.
Originally posted by 99yam40 View Postget it tight and line up the castle nut to the hole where you can get the cotter pin thru
I suspected that there was some play that enabled the prop to hammer onto the brass nut and broke it in two, then loosing the lot when decelerating.
The other theory that I didn’t accept is that Mercury used a hex stamped locking washer where the tabs are bent on to the nut faces; that some failure there made the nut spin off.
Never liked the cumbersome pieces of that arrangement though.
Originally posted by zenoahphobic View PostMaybe not relevant but many years ago I lost a brand new Mercury prop (lifted engine, bare shaft, never found).
but never lost a nut with a cotter key thru it.
I do not remember ever using a toque wench on a prop nut.
you can try and then decide to overtighten or back it back off to Ine up the hole
Â
