I have a 2004 Yamaha 300 on my skeeter. engine runs great but recently will not start unless trimmed all the way up. started on a trip to mlax lake in MN. Any ideas please? also, at times when running on plane if you trim down it will kill the engine
Weird Starting problem
If you can find another wiring harness
you could plug it into motor and controls without running through rigging tube and under deck just to see if that makes a difference/
other than that it is trouble shooting with a meter if you have the equipment and knowledge
or take to a qualified Yamaha tech
Please clarify, it doesn't start/RUN Or doesn't spin OVER.
As posted above, it sounds like the engine harness to main wiring harness isn't plugged in fully, corroded, potentially binding, etc. Un-plug and inspect those harnesses.
I would also recommend dielectric grease in each connector to prevent any corroding. Also physically remove/clean any grounds, (just looking DOES NOT COUNT either).
If the connectors pan out(no issues) time to dig deeper but start with the basic'sLast edited by TownsendsFJR1300; 10-27-2015, 07:25 PM.Scott
ÂÂ
