Hi I have serviced my Yamaha F100A but it has not cured the sneeze.
I have done:
New plugs
New fuel filters
New Anodes
New timing belt
4 carb kits carbs carefully serviced spray and wire and daylight through every hole. Float level checked and set on all 4.
Brand new super fuel.
Service if the prime starters - similar wire / spray through all holes etc...
But in idle it sneezes - see the video.
I have thought (maybe wrongly) that it was lean sneeze. The stock needle setting is 2 out. I have run it at 1.5 out. 2 out. 2.5 out. 3 out.... etc.. no difference.
I have also run it while pumping the bulb to keeo that hard to make 100% sure that each float bowl is fuly full. No difference.
It starts perfect. Runs smoothly. Just sneezes.
I don't know if it will do this under load - I can't test that at the moment.
Any ideas would be much appreciated.
I have done:
New plugs
New fuel filters
New Anodes
New timing belt
