I have a 2006 Yamaha 225 hpdi, my alarm is consistently beeping with the key on but the end is not running. When I was on the water the alarm started to beep while I was idling, and it probably was less than 5 minutes that I was idling for, but once I gave it gas it went away.....My oil tanks were full, and I had a steady stream of water. I have stock gauges with no warning lights.
I traced the harness from the alarm back to the engine and found nothing wrong, then I disconnect the oil float sensor wiring connector and the alarm went from a beeping sound to a steady alarm sound. I ohm out the oil float gauge and everything seems ok, but I'm not sure why the alarm would go from beeping to a steady sound if I disconnect the connector, I would of thought the alarm would have went off....... I also checked to fuel sensor connector and that didn't change anything when I disconnected it
Anybody have any ideas what's wrong?
Thanks in advance for your help,
Mike
Mike
