I've been meaning to ask this for a while now. I've had this engine for a few seasons and it's always been like this... When in neutral (out of the water), the prop will spin quite fast - at least like when you would put the engine into gear at an idle speed. I CAN stop the prop and it doesn't take much force (I used a piece of wood and slowly went "with the rotation" of the prop). But I've never had an engine where the prop spins as fast it does with this one. Is this normal with this era of a Yamaha? It will still spin when in the water and in neutral, but much slower.
I have, on a number of occasions (aside from when I change the gear oil, annually), pulled the drain screw on the lower unit to check the fluid for water intrusion, but I have never found any. Obviously, my fear was that the seals are bad.
This video shows the issue in a different way. We're just floating along here, and I noticed the prop spinning easily from the current.
https://youtu.be/9jAvxuBIxTE
