Connecting Yamaha F40 FETS to Raymarine a68
  • Connecting Yamaha F40 FETS to Raymarine a68
    Hello,
    this is Martin, and ive a question about the nmea2000, my Yamaha F40 FETS (Modell 2011) and my Raymarine a68.
    I've already read a lot about it, but I understand it not exactly yet.
    Maybe you can help me to correctly understand it, so I do not buy anything wrong.
    I have the Command Link Hub, the two gauges and the y-cop installed, one BUS and one device port is still available for use.
    Now i want to connect my new Raymarine a68 Plotter to the command Link HUB.
    As i understand, i can use one of these cables, to have nmea 2000:
    3861-F - Offshore Systems Yamaha Hub to N2K Micro Female Socket - 3861-F for only $61.95 ! (For the Device Port)
    or
    3862 - Offshore Systems Yamaha Hub to NMEA 2000 Cabling Extender - 3862 for only $61.95 ! (For the BUS Port)
    is that correct? are there any other options or manufacturer? since this is the only one ive found. Do i Have to cut the Red Wire?
    now when i have nmea 2000 i will need an adaptor cable from nmea 2000 to sea talk NG.
    Which could be raymarine A06046 for the Device cable above or raymarine A06045 for the Bus cable above .
    Is that correct and anything i need?
    ive found that there is also
    A06075
    A06076
    A06078
    These are the same adapter cables only in different lengths?
    i hope you will understand my english.
    thank you very much
    Martin
